A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
Posted: 2024-06-18 11:17 PM
In trying to find bad tags from a CompactLogix PLC I have modified the Citect.ini file as recommended.
[ABCLX]
DebugCategory = TAG
DebugLevel = ERROR
However I cant seem to find the log file anywhere after I restart the runtime.
I would expect it to be here "C:\ProgramData\Schneider Electric\Citect SCADA 2016\Logs\Drivers"
Am I missing something? Thanks
Posted: 2024-06-30 10:35 PM
Hi @mp231,
I'm not sure why you think this "function" has been removed from Citect SCADA 2016? I think perhaps the default or old location where the logs used to appear is different?
See Technical Note 000028633 on AVEVA Website:
https://softwaresupportsp.aveva.com/#/knowledgebase/details/000028633?lang=en_us
As you have done, set the citect.ini parameters. Then check the syslog.<IOServerName>.dat file found in the Logs directory. Then open this file and look for messages similar to this:
[ERROR] [TAG ] [0x000012ec] [21/11/2023] [10:40:53.095] [FindTag()] Root tag not found : Valve3Open
[ERROR] [TAG ] [0x4650] [21/11/2023] [10:40:53.142] [FindTag()] Field not found : Pump1.speed
If you have any issues, let us know. It would also be helpful to know what version of the ABCLX driver you are using.
Also note that version 36 of the Control Logix firmware has introduced some incompatibility, but a HF driver is available to overcome this issue:
This has been resolved as bug 3020846 in the ABCLX_5.04.02.000_HOTFIX.
Posted: 2024-06-26 05:51 PM
Apparently this function has been removed from PlantScada since Citect 2016 version.
Makes it a lot harder to locate bad tags.
Hi @mp231,
