ups continuous whistle
  • ups continuous whistle
2150
127
Posted: ‎2021-06-28 05:13 AM . Last Modified: ‎2024-03-27 01:09 AM
1980
Hi!
I have a back -ups 700, a few days started to whistle continuously and sockets are not powered.
I purchased a new battery to replace the original, but the problem is not solved.
What may have happened ?
The UPS should not make a whistling noise. You can try a reset to see if the issue clears
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If the unit continues to whistle after the reset it should be replaced.
7: Turn UPS on.
