ups BX700UI not beep anymore
  • ups BX700UI not beep anymore
2151
120
Posted: ‎2021-06-28 06:49 AM . Last Modified: ‎2024-03-26 11:07 PM
1201
Hi, it's been a few weeks my ups BX700UI doesn't emit any beeps even input voltage missing.
I tried to install parachute 3.02 on windows but there isn't any switch to re-enable the beep.
I tried to select notifies all the alarms but even in this way it does not work.
Any ideas???
Thank you
If the UPS is not beeping and PowerChute has been set to enable battery alarms at all time then there is a hardware fault. If the unit is under warranty you should contact local technical support for assistance and possible replacement.
Local support contact information will be found at this link. http://www.apc.com/it/it/support/contact-us/index.jsp
