trying to get into a AP7900
Select a Country
  • trying to get into a AP7900
BillP Leader
2150
144
Techie_apc
Techie_apc
83
Posted: ‎2021-06-29 07:12 PM . Last Modified: ‎2024-03-21 03:06 AM
3890
I bought a used AP7900. I have the IP address, but not the user/pass. I don't have a serial cable and really need to get this up and running soon. I can browse & telnet to the ip that is on the box, but I can't get in. Is there anyway to recover the password w/o a serial cable? If not, is there some way to Factory default the configuration on this thing so I can set things up myself (once again without a serial cable)?
If not, where can I buy this part number? 940-0144A I don't see it on APCs site. Better yet, how can I make a serial cable???
thanks
  • Universal Transfer Switch
Posted: ‎2021-06-29 07:12 PM . Last Modified: ‎2024-03-21 03:05 AM
I'm sorry, but "proprietary" cable pinouts for something as simple as a console connection is utterly ridiculous, and when dealing with such vital equipment, irresponsible.
As discussed here, I was able to construct my own adapter for accessing an AP7900 I had acquired second-hand. For a standard 4-pin plug, the correct pinout is:
DB9 Pin 2 - Red
DB9 Pin 3 - Green
DB9 Pin 4 - Black
Replies 6
BillP Leader
Leader
i understand and it was not my decision to make the cable proprietary. 😕
Thanks for the quick response.
Is there something special about the cable? I make and use serial cables all the time, can't beleive APC doesn't have the pinout posted somewhere?
BillP Leader
Leader
yeah, we dont have it posted cause its a proprietary cable. 😞
BillP Leader
Leader
hi,
unfortunately, the only way to reset the password on this device is to connect locally via the serial connection. as long as this is under warranty, contact APC support via email or phone and just ask if they can send a cable to you.
reference this thread if you need to.
phone support for the US - 800-890-4272
email support - esupport@apcc.com, www.apc.com/support
BillP Leader
Leader
stretch wrote:
As discussed here
Don't trust dslreports. Their information is incomplete and their moderators are mean and nobody is allowed to reply to that thread.
DB9 Pin 2 - Red
DB9 Pin 3 - Green
DB9 Pin 4 - Black
That worked for me in a pinch. I also purchased an APC serial cable 904-0144A and found that the pinout is different. It uses at least one of the outer RJ25 pins, and some of the other pins are arranged differently. The 904-0144A cable works just as well as the one I made with the pinout above. It appears there is more than one way to connect to an AP7900 PDU serial port!
DB9 Pin 2 - Red
DB9 Pin 3 - Green
DB9 Pin 4 - Black
