rbc7 and rbc11 and rbc55
  • rbc7 and rbc11 and rbc55
2150
127
Posted: ‎2021-06-29 11:20 PM . Last Modified: ‎2024-03-20 12:41 AM
3307
unless I am mistaken can one use rbc11 (no connector change required) and rbc55 (use old connectors) in sua 1500 (rbc7) - rbc7 is same battery as rbc11 (same connector 2 battery units) and rbc55 (different connector 2 battery units) - reason...found more reasonably priced rbc55 units for sale as I have multiple sua 1500 units.
  • Universal Transfer Switch
Posted: ‎2021-06-29 11:21 PM . Last Modified: ‎2024-03-20 12:41 AM
in RBC7: 2 QTY of 12V 17A that mean One(string) set of battery
in RBC55 and RBC11: 4 QTY of 12V 17A that mean Two set (string) of batteries
make sure to use same your connector and fuse.
thanks
Replies 4
no different for Volt and Amber RBC11 for old model like SU2200INET ans SU3000INET
                                            RBC55 for new model like SUA2200I and SUA3000I
there is one different only with connector and fuse change it with your old connector and fuse and it will work good.
for rbc11 and rbc 55 dimensions shown as and weight 2 batteries as 53.7
Maximum Height
6.80 inches (173 mm)
Maximum Width
5.6 inches 142mm
Maximum Depth
7.2 inches 183 mm
while rbc 7 is
Maximum Width
6 inches 152 mm
Maximum Depth
7.2 183 mm
shown difference is width as 5.6/142 vs 6 153 for rbc 11 and 55 vs rbc 7
if amp and volts the same if rbc55 is smaller in width then it will fit sua 1500 case and offer identical performance
wonder if the difference is a typo??
one of our client have purchased G35T15KH4B4S galaxy 15 kva but installed with the help of his contractor after one month the issue is with the batteries with some battery teperature fault how to get warranty claim on this
thanks
