battery cartridge connection
  • battery cartridge connection
2151
116
83
Posted: ‎2021-06-28 08:03 PM . Last Modified: ‎2024-03-26 01:41 AM
3415
this is my first ups and i am ready to connect the battery. i have a red cable and a black cable. i am assuming red is positive, black is negative. i can connect the red cable to the pos terminal, but when I do there is no ability to attach the longer black cable to the neg terminal. the black cable was originally connected to the neg terminal so when i first tried to connect the red cable to the pos terminal i got a spark. i am using model bx900r. the guide that comes with the product only shows a black and white drawing for connecting the battery cables and that is actually the original configuration that i tried.
Posted: ‎2021-06-28 08:03 PM . Last Modified: ‎2024-03-26 01:40 AM
You want to connect the black cable to the negative terminal and the red cable to the positive terminal. Upon doing so you may see a small spark which is normal. At that point you should let the unit charge for a few hours before connecting your equipment.
