What is the voltage and current rating of APC Back-UPS ES 500 battery charging leads?
  • What is the voltage and current rating of APC Back-UPS ES 500 battery charging leads?
2151
116
83
Posted: ‎2021-06-29 07:56 PM . Last Modified: ‎2024-03-21 01:23 AM
1063
What is the voltage and current rating at the charging leads of APC Back-UPS ES 500?
Simon Mandy
Posted: ‎2021-06-29 07:57 PM . Last Modified: ‎2024-03-21 01:23 AM
without a specific Back UPS 500 model, that is all I could find documented for a few models I checked.
As we have many different models that could be called "Back UPS ES 500" I checked a few and it seems like the charging wattage is about 3W. I assume you could maybe figure out amps and volts with that maybe?
Based on ohms law, a 3 watt charging circuit for this ups (which I'm 99% sure has a single 12 volt 6 or 7.2 Amp-hour cell) would be capable of putting out about 250 milliamps (mA) DC max.  3 Watts seems a bit on the low side, are you certain that's correct, Angela ?
