UTS6H install location
  • UTS6H install location
2150
127
Posted: ‎2021-06-29 11:57 PM . Last Modified: ‎2024-03-20 12:32 AM
1226
The Site Preparation and Installation Guide for the UTS6H Transfer Switch states "install the UTS within one foot of the building circuit breaker panel."  Is it critical that the UTS be located within 1' of the breaker panel?  The breaker panel for my house is in the corner of my garage, sandwiched between a wall corner and the garage door frame.  The wall studs prevent me from installing anything else within a couple feet of the breaker panel.  Is it OK to install the UTS more than a few feet from the breaker panel?
  • Universal Transfer Switch
wayne_i_apc
Lieutenant wayne_i_apc
Lieutenant
My "scientific guess" would be that the instruction to install the UTS within one foot is based on the length of the "whip" attached to the unit for connecting to the circuit breaker panel. Moving the UTS any further away will require replacement of the provided flexible conduit and connecting wiring within the conduit. Not impossible, but sure will add to the installation effort! I'll rephrase what Angela has already said with "closest possible is best".
I too am interested to see if or what APC recommends for a maximum distance from the circuit breaker panel!
How far from the breaker panel do you think you need to go?
SecretSquirrel - can you verify this is OK? I think as close as possible is OK - few feet should be acceptable but I'll defer to SecretSquirrel for confirmation.
wayne_i_apc
Lieutenant
