Posted: 2021-06-28 02:33 AM . Last Modified: 2024-03-27 02:22 AM
I dont know what is going on, when ever im playing Arma it starts using my battery power, why.????????????????
it mostly happens when im in action, or i throw smoke or grenade, it then goes beeeeeeeeeeeeeeeeeeeeeeeep, the green led is still bright, and when im looking away or in to the sky, it stops.
I have a program (powerManager:Auto) that monitors the battery, it says that my input Voltage is 234 and the output Voltage is 235.
it also haz a load bar that shows(I dont know what) but it gos up to 60 70 when playing thae game and there is a little action
PLEASE HELP, thanks in advance
The symptoms indicate the UPS is being overloaded. Most likely what is happening is the video card is drawing a large amount of power during the game? You can test by putting a meter between the UPS and the system. You should also check the video card specification. The UPS only provided 360 watts so if the video card draw an amount in that range that would indicate you need to trade up to a larger UPS.
