SUA1500I 230v 50Hz 230v 60Hz - default power output - how to?
  • SUA1500I 230v 50Hz 230v 60Hz - default power output - how to?
2150
127
Posted: ‎2021-06-29 03:36 AM . Last Modified: ‎2024-03-22 01:21 AM
I have a SUA1500I 230v 50Hz 230v 60Hz unit being sent to me and I need to know if I can use it in the manner output below.
Charge @ 230v 60Hz, turn unit off or reset it to factory defaults (how??), unplug it from wall outlet, plug a 230v 50Hz computer power supply into the unit and power it up so the unit supplies 230v 50Hz to the computer power supply.
I know this is not the intended use and I know there may be a work around on resetting to factory defaults which may void the warranty, I'm not concerned if it violates the warranty, I'm just evaluating if I can use this unit in the mentioned procedure and how to get it to output 230v 50Hz from a cold start after it is charged from 230v60Hz.
I have 230V60Hz mains and I need it to supply 230v50Hz to a computer for a short duration for a test, nothing more.
thank you for any input or direction.
Message was edited by: sunbeachfun
Replies 0
