PCSS shutting down my PC within seconds
  • PCSS shutting down my PC within seconds
2150
127
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-06-10 06:26 PM
2184
Hi all,
My PCSS is login off and shutting down my PC few seconds after power outage.
The UPS is brand new, under 7 days old from use.
I'm using Win11 24H2 x64, fully updated (build 26100.4202).
UPS model: Back-UPS BX2200MI
Firmware: 378700G -001300G / 01.01a (1201 - 19)
PCSS version 1.3.0.301 (build 1.3.0-b43da2baa)
Fresh installed last PCSS version available too.  I checked every setting on PCSS, and I even checked "Do not shut down in the event of a power outage."
I'm using power plan to "high performance" also under Windows.  I cannot figure out why PCSS keeps shutting down my PC within seconds from power outage.
  • Home & Office - UPS & Software
  • Bx2200mi
  • PCSS
Replies 9
Kirk
Posted: ‎2025-06-11 01:15 AM
2177
Provide the following image capture or logs: Event, Data, UPS
What is the attached (wattage) load seen by the system?!? Disconnect the USB cable from the computer than remove AC Power from the UPS.
How does the unit behave and how long does it run for?
Questions Ask . . . 👍
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-06-11 05:59 PM
In response to Teken
2165
If I disconnect the USB cable, everything is fine, the UPS continues to works and Windows doesn't shutdown.
I had to disconnecting USB cable and using "shutdown -a" on cmd on power outage.
Kirk
Posted: ‎2025-06-12 01:57 AM
In response to Gradius
2162
The logs I was asking about are from PCSS not Windows OS. Regardless, uninstall PCSS software and reboot the computer.
Install PCPE using this APC Resource link and report back how the system behaves once setup PCPE than remove AC power from the UPS.
https://www.apc.com/us/en/download/document/APC_PCPE_310/
Lastly, what does the system indicate as the wattage / load?!?
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-06-12 02:48 PM
2143
About the logs, I see.    Just unstalled PCSS, and now I'm running the old PCPE, so far, is working perfectly.  No sudden shutdown.
As for load, it stays around 12% in "standby", and the max I saw was around 40% (while gaming).  I use an UPS meter gadget, so I can see it in near-realtime the status from UPS (attached image).
Kirk
Posted: ‎2025-06-13 03:26 AM
2136
That’s great to hear and appreciate the quick response as to the results of using PCPE vs PCSS.
Please consider marking that reply as an interim solution so it may help others asking the same.
You may consider contacting APC Technical Support to see if they can help identify what the problem is with PCSS that is causing this issue.
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-06-22 09:19 PM
1994
Well, it was fixed, however, at least once a day (or 24h), the APC loses communication from USB (a second or so).  I even changed the cable with a professional one, and it continues to happen.  I believe is from bad driver.
Kirk
Posted: ‎2025-06-23 03:34 AM
1992
That sounds more like a power save / energy management issue. Disable all power management for the system especially the USB ports.
Change the USB port the system is using to another and report back the results. Insure the cable is NOT going through a USB Hub.
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-09-04 05:04 PM
@Teken I always disable everything related to power when I install windows.
Gradius
Crewman Gradius
Crewman
Posted: ‎2025-09-04 05:06 PM
Also, I never use USB hub for those devices, only my flash drive.
