Posted: 2021-06-29 07:33 PM . Last Modified: 2024-03-21 02:49 AM
I am looking for a small UPS that can run a couple lights for about 10-15 minutes on battery power when needed. Preferably when the power goes out, there would be no beeping, or an option where the beeping could be turned off. Any suggestions?
[check this out|http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUA1500X413]
it is a APC Smart UPS 1500 VA 120V USB with alarm disabled
it is currently the only size unit i see with this option but anything with x413 should have the alarm disabled. this size unit may be a bit too large for your application but i thought i'd throw it out there.
Well on our units you could disable audible alarms, the only caveat there is that critical 'warnings' will always emit their audible component. So something like low battery warning, bad battery, etc. Normal on battery operations would not. If you need a completely silent UPS that is 'small' we simply do not have a way to silence all alarms.
Except the one below.. 😛
Message was edited by: syn2083
