New out of the box BX900R overheating?...
Select a Country
  • New out of the box BX900R overheating?...
BillP Leader
2150
150
83
Posted: ‎2021-06-29 07:12 PM . Last Modified: ‎2024-03-21 03:06 AM
1248
Hello;
here's the issue;
I bought this APC BX900R UPS
I set it up in my house;
going by the directions to charge it 18 hours first before connecting anything
so I get up the next day to find the whole thing hot as a firecracker (with nothing plugged into it)
(if it was any hotter I could have left my finger prints melted into the plastic case)
so I unplugged it and left it for the day
and plugged it back in when I got home after work
this time it heated up and the internal fan came on and stayed on and it got hot again
so I tried hooking it up to my machine, to see if having the power used would make it go to normal temp:
Compaq P4 2GHz
with 1 HP 8000 series external USB CD RW
& 1 17" CRT Monitor
it's still hot, not as hot as the first time but the fan stayed on the whole time and remains on even when everything is powered down and the UPS is disconnected from the equipment and from the plug
we have a "Smart-UPS 1500" on the server & one on my workstation @ work and it never gets hot and the fan never comes on except when I first turn it on and it does the self test.
is this BX900R fried out of the box?
  • Universal Transfer Switch
Hello;
it was definitely "Hot" as I said if it was a few degrees more I could have imprinted my finger prints permanently into the plastic case
and with nothing plugged into it.
now when I plug it in it's always hot and the fan is going constantly
it's not as hot as the first time but it is still hot enough for the temp sensor to start the fan.
it's sitting on a tiled floor in a basement and it's never above 65 F or around 17 C
I checked the inspection slip and it was mfg. in April.
I'll try calling support on mon when I'm off.
Edit:
Last month, I ran a test in which the battery was drained until the fast beep tones started
when I plugged it back into line, I received the single constant tone indicating some sort of failure in the unit.
RMA'd
Message was edited by: Richard FDisk
EZ_Button_apc
EZ_Button_apc
Contributor
The unit certainly should never get hot to the touch. Maybe just a bit warm .
I'd give support a call at this point. 800-890-4272
Hello;
Edit:
RMA'd
