My Back-UPS XS 700U Shuts down the PC but does not go itself to sleep mode
  • My Back-UPS XS 700U Shuts down the PC but does not go itself to sleep mode
2151
122
Posted: ‎2021-06-28 07:38 AM . Last Modified: ‎2024-03-26 04:07 AM
885
Currently, I'm testing Back-UPS XS 700U in the following scenario on an Ubuntu powered PC with installed and running UPS Daemon, that is connected to UPS by USB:
1. I cut the power on UPS
2. Deamon initiates shut down on PC
3. PC is successfully shut down.
4. UPS starts beeping 3 times every minute.
5. In this condition I have assumed that the power from the PC is already cut (by UPS going to sleep mode) .
But my assumption was wrong. If I press the power key on PC it will be started. It means that the signal to UPS to power it down and saving battery is not received by UPS (Or is not sent rfom PC at all) and UPS is still running on Battery :
Have you any idea what could be the problem.
Actually, my goal is being able to successfully powering off the  UPS after PC shutdown to be able to Start PC again automatically when the power comes back (I already have ALWAYS ON on BIOS and checked it without UPS)
The followings are the status of the UPS :
APC      : 001,036,0906
DATE     : 2018-11-27 17:28:59 +0100
HOSTNAME : Precision-Tower-3420
VERSION  : 3.14.12 (29 March 2014) debian
UPSNAME  : Precision-Tower-3420
CABLE    : USB Cable
DRIVER   : USB UPS Driver
UPSMODE  : Stand Alone
STARTTIME: 2018-11-27 17:27:52 +0100
MODEL    : Back-UPS XS 700U
STATUS   : ONLINE
LINEV    : 232.0 Volts
LOADPCT  : 3.0 Percent
BCHARGE  : 97.0 Percent
TIMELEFT : 135.4 Minutes
MBATTCHG : 100 Percent
MINTIMEL : 1 Minutes
MAXTIME  : 1 Seconds
SENSE    : Medium
LOTRANS  : 140.0 Volts
HITRANS  : 300.0 Volts
ALARMDEL : 30 Seconds
BATTV    : 13.7 Volts
LASTXFER : Low line voltage
NUMXFERS : 0
TONBATT  : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
SELFTEST : NO
STATFLAG : 0x05000008
SERIALNO : 3B1834X66756
BATTDATE : 2018-08-23
NOMINV   : 230 Volts
NOMBATTV : 12.0 Volts
NOMPOWER : 390 Watts
FIRMWARE : 924.Z3 .I USB FW:Z3
END APC  : 2018-11-27 17:29:08 +0100
Hi Bill,
Thanks for your reply. You were right.
It seems the problem is APCUPSD in Ubuntu 16.
I found some workarounds to send killpower before Ubuntu shuts down USB communication:
creating (and of course doing chmod +x on) a script at /lib/systemd/system-shutdown/apcups-killpower
#!/bin/sh
if [ "$1" = "poweroff" -a -f /etc/apcupsd/powerfail ]; then
    /etc/apcupsd/apccontrol killpower
fi
For more information please refer to:
https://bugs.launchpad.net/ubuntu/+source/apcupsd/+bug/1634572
Looks like you are running APCUPSD. I know that APCUPSD offers KillPower when running on Windows. I do not know what is used on Linux. I suggest you check with the APCUPSD group.
Hi Bill,
#!/bin/sh
fi
