I need some help! - Automatic Voltage Regulator?
  • I need some help! - Automatic Voltage Regulator?
2150
127
Posted: ‎2021-06-29 10:22 PM . Last Modified: ‎2024-03-20 03:02 AM
I need some help!
I am working with a large senior housing building.
I installed a WIFI system for the residents.
My Problem is the WIFI power supplies ( 120/4amp/5vdc )
for the WIFI routers are burning out every 6-8 months
( I have tried different models )
I have tested the outlet voltage and it varies from 122-125v ac
I believe that because the voltage is to high it is causing the
transformers to burn out quickly - I need a fix for this!
I am looking at ..
APC Line-R 1200VA
APC LE600 Line-R 600VA
Or is there something better ?
I think if I am not mistaken that BOTH vers of the Voltage Regulator
only work to REDUCE voltage when the AC voltage reaches 127v-ac
I need something that keeps the AC voltage 118v120v !!!!
Is there a solution to my problem ?
  • Universal Transfer Switch
Replies 0
