How good is the APC Back UPS 1500 XS? Are you happy with yours?
Showing results forΒ
Did you mean:Β
  • How good is the APC Back UPS 1500 XS? Are you happy with yours?
2151
120
Posted: β€Ž2021-06-28 10:15 PM . Last Modified: β€Ž2024-03-25 11:14 PM
914
I was just wondering if you can recommend the APC Bak UPS 1500 XS? I have heard that the LCD load display id totally inaccurate.. is this true?
Does it have a built-in cooling fan?
Has the 1500 proven to be reliable?
Thanks.
Message was edited by: hassiman
I would like to add a comment to this.  I have a Back UPS 1500 XS with LCD screen which I have been happy with along with past products from APC.  However when one of the fans recently started making noise I called them up and asked for a replacement.  They said the fan cannot be replaced, so I should get a new unit... what?!?!  All this plastic and printed circuit boards and inverter and batteries should be thrown out because of a $13 fan?
There are only 2 moving parts in this whole thing (both fans) and I was baffled that they would not make these easily replaceable.  Even without the money issue the environmental implications of this are insane.
I pulled the back off and then took out the fan and and found the manufacturer in China by typing in the part number (Jamicon KF0420B2MM-R).  Unfortunately that manufacturer does not seem to sell fans in the US market retail so then I took the specs and found the most similar fans on Digi-Key I could.  I ordered two of them (one with overcurrent alarm and the other with tach output) and when I got them saw that the wire color matched for the o/c alarm one so I soldered it in.  This was Digikey part# 1053-1414-ND, Orion Part number OD4020-24HB02A FAN DC 40X20 24V W/ O/C ALARM
Put it all together and its now working fine.  This will be the last of these units I purchase until they correct this simple design flaw.
i work for APC but this is my personal opinion..i have an BX1500LCD (XS 1500) and i like it. it does have a cooling fan for when the unit is charging and operating on battery . the wattmeter isnt as accurate with small loads on it (less than 100 watts) compared to when it has a higher load on it. the unit looks very sleek. this has been very reliable for me and i'm not just saying that πŸ˜‰
Β
