Emails aren’t send from UPS
  • Emails aren’t send from UPS
2150
127
Imri
Imri
Cadet
Posted: ‎2024-02-08 12:51 PM . Last Modified: ‎2024-02-08 12:52 PM
1159
Hi community,
I use APC Back-UPS BE-850 VA and W10 OS, PowerChute Serial Shutdown v1.0.
I’m not able to get emails from PowerChute if VPN is connected. Without VPN it works.
I use smtp.google.com, TLS. VPN provider is not blocking the mail server, I can go to gmail using web browser. Tried to use direct IP addresses but it still doesn’t work.
Exception for firewall is set directly once I installed the PowerChute. What else can be wrongly set?
Getting error message from log:
211|
93gz
217
2181
2024-02-06 16:13:03,053 [gep160477753-86] INFO
- [DataModels.M11EventGenerator. ()] sendTestEmail() - called
2024-02-06 16:13:03,085 [SMTPMa11Worker] WARN
- [SUTPMaller. SMTPMa11Worker. (1] Subject :MN : PowerChute Serial Shutdown Test Ema11
2024-02-06 16:13:24,584
(SMTPMailWorker) WARN - [SMTPMailer.SMTPMailWorker. ()] SMTPMailConfigException :com.sun.mail.util.MailConnectException: Couldn't connect to host, port: smtp.gmail.com, 587; timeout -1;
nested exception is:
java.net.ConnectException: Connection timed out: connect
2024-02-06 16:13:24,584 [SMTPMailWorker] WARN
- [SMTPMailer. SMTPMailWorker. ()] com.apec.11.components.SMTPMailer. SMTPMailConfigException: com.sun.mail.util.MailConnectException: Couldn't connect to host, port: smtp.gmail.com, 58
nested exception 13:
18v8.net.Connen:Con  :
Please help me. Thank you.
  • Home & Office - UPS & Software
Posted: ‎2024-02-13 07:54 AM
1124
@Imri
The log shows that smtp.gmail.com port 587 is not available. That indicates the VPN is blocking access to the port. Have you consulted your VPN admin and have you searched online for a solution?
I did a Google search and found many posts for the issue. Example https://support.mozilla.org/en-US/questions/1200505
Imri
Imri
Cadet
Posted: ‎2024-02-13 01:05 PM
In response to BillP
Yes, but they don’t provide Split Tunneling for now.
Any other ideas? Or use different SMTP provider?
Imri
Imri
Cadet
Posted: ‎2024-02-13 01:49 PM
The first thing what was I added the FW exception. So this is out... Doesn't work...
