Posted: 2021-06-28 04:00 AM . Last Modified: 2024-03-27 02:01 AM
hello, having a problem with my apc ups Es 750. It's a constant green light with a strange noise. Not the same noise when the battery need to change. Battery does need replacement. But when I plug it in I get a green constant light and the noise. The model number is BE750BB
Green light is on and constant tone and when plugged in, outlets still work.
These are the Audible tones and indicators for the BE750BB
On Line: Green power on LED lit with no tones
On Battery: 4 beeps every 30 seconds, the power on LED will be off while beeping
Low Battery: Constant beep, the power on LED will be off while beeping
Overload: Constant tone, there is no power from the outlets at all
Low voltage sleep mode: 1 beep every 5 seconds
Posted: 2021-06-28 04:01 AM . Last Modified: 2024-03-27 02:01 AM
Reset the unit
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If after resetting the unit the UPS still has a constant tone with nothing plugged into it it will need to be replaced.
