Continue
  • My Subscriptions
  • Events
Confirming validity of transfer events
  • Confirming validity of transfer events
BillP Leader
2151
156
83
Smart-UPS
Tfj
Tfj
Explorer
Posted: ‎2022-08-13 02:29 PM . Last Modified: ‎2022-08-13 03:03 PM
2376
I started monitoring my UPS's about 3 months ago with apcupsd and email alerts.  In this time I have noticed several alerts that the UPS went to battery and came back a second later or less than a second later.
What techniques could I use to validate that my UPS is properly detecting problems with input power?
I have many systems that are not on ups and using the same input power and they are not disrupted. In general power outages here happen once a year or less.
I know that I can adjust the sensitivity on my APC upses. I did not ask how to do this in this thread
I want to know how to validate my UPS's observations of there being a power disruption.  Or how to substantiate my APC UPS's assertion that there ever was a problem with power
So far I have tried placing a camera on the UPS that can also see a light powered by the same circuit the power of the UPS. It records continuously at 30fps. I have experienced two events now where there was no discernible flicker of light during the supposed outage.
So I am actually wondering now if my APC UPS is faulty and detecting failures when there are no failures. Please help me disprove this.
Here's the email i got this morning, in case something sticks out to you...
Subject:. Hhghjn.org UPS Hhghjn.org Power Failure !!!
APC : 001,038,0999
DATE : 2022-08-13 07:02:28 -0500
HOSTNAME : Hhghjn.org
VERSION : 3.14.14 (31 May 2016) redhat
UPSNAME : Hhghjn.org
CABLE : USB Cable
DRIVER : USB UPS Driver
UPSMODE : Stand Alone
STARTTIME: 2022-07-05 17:27:29 -0500
MODEL : Back-UPS XS 1500 LCD
STATUS : ONBATT
LINEV : 124.0 Volts
LOADPCT : 11.0 Percent
BCHARGE : 100.0 Percent
TIMELEFT : 10.8 Minutes
MBATTCHG : 5 Percent
MINTIMEL : 0 Minutes
MAXTIME : 0 Seconds
SENSE : Medium
LOTRANS : 88.0 Volts
HITRANS : 139.0 Volts
ALARMDEL : 30 Seconds
BATTV : 27.2 Volts
LASTXFER : Low line voltage
NUMXFERS : 4
XONBATT : 2022-08-13 07:02:29 -0500
TONBATT : 1 Seconds
CUMONBATT: 18 Seconds
XOFFBATT : 2022-08-06 17:50:14 -0500
LASTSTEST: 2022-08-06 17:50:06 -0500
SELFTEST : NO
STATFLAG : 0x05060010
SERIALNO : 3B0916X6937177
BATTDATE : 2022-05-25
NOMINV : 120 Volts
NOMBATTV : 24.0 Volts
NOMPOWER : 865 Watts
FIRMWARE : 837.H7 .D USB FW:H7
END APC : 2022-08-13 07:02:30 -0500
  • Home & Office - UPS & Software
Replies 5
BillP Leader
Leader
Posted: ‎2022-08-17 08:43 AM
2356
@Tfj
If you want a scientific analyses you should use an oscilloscope to test the UPS input. If you know an electrician or electrical engineer you could ask to borrow one to run the test.
Tfj
Tfj
Explorer
Posted: ‎2022-08-17 01:51 PM
In response to BillP
2348
Okay, I'll borrow one a couple days before the next unexpected transfer to battery.
What's the command to see when the next time it will transfer?
BillP Leader
Leader
Posted: ‎2022-08-18 07:44 AM . Last Modified: ‎2022-08-18 07:47 AM
In response to Tfj
2332
@Tfj
 There is no command to determine when the next power event will be. The oscilloscope will monitor and record the power. If the UPS switches to and from the battery, you will check to see what the oscilloscope recorded for the time.
Tfj
Tfj
Explorer
Posted: ‎2022-08-18 07:52 AM
2328
So how would I know when to connect the oscilloscope?
Do you think I should get one of those isolators for measuring line voltage?  Or just wind a conductor around hot and another around neutral and infer voltage via the electrical noise it picks up?
There's a 4 channel that I can use so I might do that for hot, neutral, and ground (why not), and use the 4th to monitor an led that I'd keep in frame of video and blink a timestamps pattern so I can line up video and scope. I've got an Arduino I can use for the ledi guess.
Tfj
Tfj
Explorer
Posted: ‎2022-08-20 03:29 PM . Last Modified: ‎2022-08-21 05:56 AM
In response to Tfj
so i learned that those isolators are called 'differential probes' and they cost like $300 a piece.  Not doing that...
I think I read something about a 'potential divider'.  Basically taking 200 resistors, and connecting the first one between earth and the probe tip.  and clip probe ground to earth.  Then string the other 199 resistors along from the top to hot.
It sounds simple.  I'd expect to see one 200/th of the actual oltage on that channel.  But wouldn't the string of resistors become in efffect a short, or a space heater right quick?
I don't feel like going out and getting a tonne of resistors either.  And what ohm would I use..
Then I got to thinking, that big string of resistors is a lot like the big strings of Christmas lights that I have sitting int he basement anyway.  Each bulb is only rated for 3 or 5 volts.  So perhaps I could take two strands in series to keep that voltage under 2v.  And attach the probe one bulb away from ground.
Actually those would be plugging between hot and neutral normally.  using them between hot and ground would surely trip my gfci outlet.  Though i suppose I could find a circuit that's not GFCI protected
Or I could just attach the probe ground to neutral.  or leave it loose.  The resistance between the scope's ground and neutral should be pretty minimal.
@BillP  Do APC UPSes monitor or react to any potential between ground and neutral?  Or do they just react to the power between hot and neutral? (Easier to measure)
