Can anyone help me, ask input Voltage of USB HUB's power Adapter
  • Can anyone help me, ask input Voltage of USB HUB's power Adapter
2150
125
Posted: ‎2021-06-28 09:04 PM . Last Modified: ‎2024-03-26 12:45 AM
1276
hello eveyone,I come from Germany.
I just want to by the APC USB 2.0 4 PORT HUB
Produkt No. is 19500SG-1G
!http://www.apcmedia.com/resource/images/500/Front_Left/19500SG-1GFL.jpg!
My problem is our Output Voltage is 220V. I wonder if I can use the power adapter in Germany.
Does anyone has the same usb hub, could you please have a look if the power adapter has a Input Voltage Periode, e.g 110V~220V.
thank you for your help.
  • help
  • hub
  • usb
the input to the hub is likely 5 or 12v. If you can find an adapter with adequate amperage that accepts 230v input, you can use that adapter.
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Yun Ling,
Unfortunately the power cable for the USB hub states it requries a nominal 100-120VAC power source.
thanks a lot
