Back-UPS model BE700G - too slow to respond?
  • Back-UPS model BE700G - too slow to respond?
2151
116
83
Rory_apc
Crewman Rory_apc
Crewman
Posted: ‎2021-06-29 04:21 AM . Last Modified: ‎2024-03-22 12:51 AM
900
Got one of these units a couple of weeks ago mainly because brownouts cause my home ADSL modem/ router to drop out. This means it comes back with a new IP address and that can cause problems with email blacklists.
So I was hoping that once I found a "good" IP address the router would keep hold of it by staying powered up.
Unfortunately, the BE700G just doesn't catch these interuptions - had one today and everything went off. Power came straight back but everything connected - LCD monitor, NAS, Printer and the modem/router all had powered down and back again.
I've got it set on max sensitivity, but am I just expecting too much for it to catch glitches?
Rory_apc
Crewman Rory_apc
Crewman
Rory_apc
Crewman Rory_apc
Crewman
Sorry not to reply - been travelling for a couple of days.
Yanked the mains plug out and it worked perfectly - modem/router stayed up which is precisely as I'd hoped.
So I guess the issue is exactly as you suggested - that the switchover point is at too low a voltage so when the voltage dips for a time it doesn't switch to battery but the voltage is too low to hold the connected equipment up.
It's all connected through wallwarts or power bricks and I had thought that might be a good thing as the voltage input range is usually pretty wide.
Message was edited by: Rory
Rory_apc
Crewman Rory_apc
Crewman
