84419members
353605posts
Back-UPS ES 350: External car battery fried UPS
rickrcomm_apc
131
This was originally posted on APC forums on 7/7/2013
Ok, I'm not a newbie electronics guy.  Been doing electronics my whole life.
After a 3 day power outage here, I decided it would be good to have a longer UPS power supply so I decided to attached the UPS battery leads to a 123V car battery.  The only load was two 100watt light bulbs.  Had a wattmeter attached to verify.
Worked for 25 minutes until UPS shut down (on low voltage, I assume.)  UPS top was very hot.  Recharged battery and let everything cool down.  Tried it again.  Got a beep when I pressed the power button but the inverter in the unit would not turn on so no power at the backup receptacles.
Since 200watts was well within the load spec of the unit, I assume that it is not rated for continuous duty, anyway for 25 minutes.
Can anyone confirm before I try this on my second of four units?
I know I should just buy a standalone inverter but since I had the UPS's and they have some monitoring built in, I thought I'd give it a try.
Thanks for any insights.
Rick
Tags (3)
Janeway
Janeway
Re: Back-UPS ES 350: External car battery fried UPS
This was originally posted on APC forums on 7/9/2013
rickrcomm wrote:
Wonder if there would be any way to get a schematic of the board to look at the components?
While I can't publish the schematics, you can monitor Schneider Electric Careers and sometimes there are job openings in Billerica 🙂
3 Replies 3
Janeway
Janeway
The thermal design of the UPS is based on how much energy the standard battery can store. If you do it again, you might want to add additional cooling.
rickrcomm_apc
So, you're saying that if I draw power out of the battery at or below the rated load with a bigger battery than design, it will overheat?  That would mean that it had not reached steady state temperature on the components with the standard battery but that the temperature was still rising.  Sounds like this would not be a conservative design.  I get your point, but am surprised that they would design it that way.
Rick
Janeway
Janeway
