BX1500G shows no bars on battery indicator nor time remaining
  • BX1500G shows no bars on battery indicator nor time remaining
2151
116
83
Posted: ‎2021-06-28 06:05 AM . Last Modified: ‎2024-03-27 12:26 AM
585
The battery went kaput on the unit a while back and I got around to replacing the batteries.
With AC plugged in and batteries in, I get a solid battery with no bars and no time remaining.
Disconnect AC power, I hear it switch to battery as the fan kicks on, and it still has the same battery display with no bars and no time remaining.
I know the battery is good as I have another of the same unit and swapped it out and it works fine.
Try to reset the unit
To do this, follow the below procedure;
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
7: Turn UPS on.
