APC SE 500 CONTINUOUSLY BEEPING
Showing results forย
Did you mean:ย
  • APC SE 500 CONTINUOUSLY BEEPING
2151
116
83
Posted: โ€Ž2021-06-28 04:03 AM . Last Modified: โ€Ž2024-03-27 01:59 AM
736
I have here a APC SE 500, when i plug-in the AVR of my computer the UPS starts to beep but when i move the UPS to another wall outlet the beeping are gone and it works fine . what might be the problem is the battery drained? or i have a problem in my wall outlet? don't want to buy a new battery if it's not the problem. please help me ๐Ÿ™‚ thank you and sorry for my bad english XD please understand xD
If the unit is beeping very 30 second when plugged into that specific wall outlet then the UPS is switching to battery because it does there is an issue with the AC at that outlet. You should have an electrician check the outlet to determine the problem with the outlet.
oh okay . maybe my wall socket have a problem because when i plug another UPS in the same outlet the UPS beeps ๐Ÿ™‚ so its the wall outlet ๐Ÿ™‚
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
