APC RAISED FLOORING
  • APC RAISED FLOORING
2150
127
Posted: ‎2021-06-30 12:04 AM . Last Modified: ‎2024-03-20 12:27 AM
1314
APC RAISED FLOORING
Dear All,
I would like to know that do we have any RAISED FLOORING product by APC or Schneider Electric? I saw "KoldLok« Integral Raised Floor Grommet" (AR7720/ AR7730/AR7740) but I dont understand that whether is it a  particular raised flooring or only an accessories to improve rack cooling efficiency by preventing air recirculation and reducing bypass airflow.
If we have a Particular raised flooring system in apc or schneider electric with 600 x 600 mm tile size. Please let me know the part number or link?
Thanks a lot.
War
  • Universal Transfer Switch
Hi Angela and Battman, Thanks both of you.
At last I found exactly what I was searching for,
https://www.apcc.com/products/resource/include/techspec_index.cfm?base_sku=ACAF100&tab=documentation
The part no. is ACAF100
but u guys cooperation and help is superb. Thanks a lot once again.
War
It sounds like Uniflair, which is now a =SE= company, provides this type of thing.
I found information here -> http://www.uniflair.com/EN/prodotti/pavimenti.aspx and from what I was able to ascertain, these are raised floor tiles.
Here is also the Uniflair stuff offered via apc.com but I don't see anything specific listed there, only floor stands -> Cooling Solutions - Home, Business & Data Center Cooling | APC <meta http-equiv="Content-Type&…</a><...
We use Koldlok product - from a company called Chatsworth - in our main Data Center on campus, it is a grommet-like opening with special dense fibre/hair like fingers across the opening which allow cables to pass thru but not a lot of air, so you maintain underfloor static pressure. You need to cut an opening in your floor tiles to fit. Here is a link:
http://www.chatsworth.com/Products/Cabinet-and-Enclosure-Systems/Accessories/Thermal-Management-Acce...
War
