APC Line-R 1200
  • APC Line-R 1200
2150
127
Posted: ‎2021-06-28 05:30 AM . Last Modified: ‎2024-03-27 12:56 AM
1262
APC Line-R 1200
I have a Tv, home theater/DVD player and sky TV unite plugged into it.  Lately It will not start.  I have to unplug plug all, start and then plug them in.
An idea on the fault.
Russ
  • 1200
  • failure
Posted: ‎2021-06-28 05:30 AM . Last Modified: ‎2024-03-27 12:55 AM
Hi Russell,
There is not much troubleshooting to be done with these units unfortunately. What could be causing the issue is an overload or short that is causing the unit to turn off.  I would recommend checking all of your wires on the unit and your attached devices for fraying wires or try the unit on a different circuit and see if the issue stops.  Otherwise there could be an internal issue with the unit, and in that case it would need to be replaced.
Schneider,  could you please advise your thoughts.
Hi Russell,
