APC A/V Model J15 Issues
  • APC A/V Model J15 Issues
2150
125
Posted: ‎2021-06-29 08:07 AM . Last Modified: ‎2024-03-21 04:22 AM
1241
Does anyone else have experience with the J10/15 models of the APC A/V line? I purchased one and have set it up, but the LCD 'screensaver' does not work at all. It never turns on. I am concerned about spending hundreds and hundreds of dollars for a unit that may have a bad display in a few years (or months!). If the screensaver doesn't work and the display gets burn-in, will APC replace the display?
Is there a firmware update to fix this issue? Or some other way to fix the screensaver feature?
Message was edited by: mordac
Posted: ‎2021-06-29 08:07 AM . Last Modified: ‎2024-03-21 04:21 AM
Hi Mordac,
We do have an APC Knowledgebase that would explain how does the screensaver works, though it says S10/S15 it also applies to your UPS. Also with regards to the burn-in issues, if that would happen and the unit is in warranty we would replace it.
[Why is there a Screen Saver on the APC AV S10/S15 and how does it work?|http://nam-en.apc.com/app/answers/detail/a_id/7331/kw/7331]
Unfortunately the load percentage on which the screensaver gets activated cannot be changed.
Hi Mordac,
I appreciate the reference to the knowledge base - thank you for updating me. Is there a way to adjust the load % such that the screensaver will activate at a higher load? My UPS ls pretty much always at 8% load.
