ssh to PDU slowly
  • ssh to PDU slowly
smallfish01
Crewman smallfish01
Crewman
Posted: ‎2022-04-29 11:56 PM . Last Modified: ‎2022-04-29 11:57 PM
ssh to PDU slowly
I have some of 7921 PDU, when I ssh to device, it needs over 30 second to prompt for the password, I enable debug and found when running "debug1: expecting SSH2_MSG_KEXDH_REPLY" it need over 20 second.
The whole debug as below:
# ssh -vvv admin@192.168.1.7
OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 58: Applying options for *
debug2: resolving "192.168.1.7" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.1.7 [192.168.1.7] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /root/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: identity file /root/.ssh/id_dsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa type -1
debug1: identity file /root/.ssh/id_ecdsa-cert type -1
debug1: identity file /root/.ssh/id_ed25519 type -1
debug1: identity file /root/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.4
debug1: Remote protocol version 1.99, remote software version cryptlib
debug1: no match: cryptlib
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.1.7:22 as 'admin'
debug3: hostkeys_foreach: reading file "/root/.ssh/known_hosts"
debug3: record_hostkey: found key type RSA in file /root/.ssh/known_hosts:7
debug3: load_hostkeys: loaded 1 keys from 192.168.1.7
debug3: order_hostkeyalgs: prefer hostkeyalgs: ssh-rsa-cert-v01@openssh.com,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,ext-info-c
debug2: host key algorithms: ssh-rsa-cert-v01@openssh.com,rsa-sha2-512,rsa-sha2-256,ssh-rsa,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,ssh-dss
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: diffie-hellman-group1-sha1
debug2: ciphers ctos: aes128-cbc,aes256-cbc,3des-cbc,blowfish-cbc
debug2: ciphers stoc: aes128-cbc,aes256-cbc,3des-cbc,blowfish-cbc
debug2: MACs ctos: hmac-sha1,hmac-md5
debug2: MACs stoc: hmac-sha1,hmac-md5
debug2: reserved 0
debug1: kex: algorithm: diffie-hellman-group1-sha1
debug1: kex: host key algorithm: ssh-rsa
debug1: kex: server->client cipher: aes128-cbc MAC: hmac-sha1 compression: none
debug1: kex: client->server cipher: aes128-cbc MAC: hmac-sha1 compression: none
debug1: kex: diffie-hellman-group1-sha1 need=20 dh_need=20
debug1: sending SSH2_MSG_KEXDH_INIT
debug2: bits set: 511/1024
debug3: send packet: type 30
"Here: waitting 20 seconds"
debug3: receive packet: type 31
debug1: Server host key: ssh-rsa SHA256:CvmQW3QFARTYw+mYDDs9OzbZkKel1JGqrM2hatwSbHo
debug1: Host '192.168.1.7' is known and matches the RSA host key.
debug1: Found key in /root/.ssh/known_hosts:7
debug2: bits set: 515/1024
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 4294967296 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /root/.ssh/id_rsa (0x5654a8d989b0)
debug2: key: /root/.ssh/id_dsa ((nil))
debug2: key: /root/.ssh/id_ecdsa ((nil))
debug2: key: /root/.ssh/id_ed25519 ((nil))
debug3: send packet: type 5
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
Authenticated with partial success.
debug1: Authentications that can continue: password
debug3: start over, passed a different list password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup password
debug3: remaining preferred: ,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
admin@192.168.1.7's password:
  • Datacenter UPS
Replies 0
