Posted: 2021-06-25 11:15 PM . Last Modified: 2024-03-19 03:17 AM
Can you tell me how to get my Back-UPS ES 550 to stop its screech? It is a model # BE550R. I suspect there was a power outage. The "Replace battery" light is not on so I assume it is fine. I have a simple paper shredder plugged into the surge protector and it works, but I am afraid to plug my computer in, in case it has some electronic problem. I have tried unplugging the unit and also hitting the Reset button, but still a shrill continuous sound.
Hi Barbara
This video shows you how to disconnect and reconnect the battery
Regards
Matt
Try the reset procedure and after that if the unit still makes the noise it should be replaced.
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
Thank you, but how do i disconnect the battery? I got it out, but there is a black wire & a red wire. Which do I disconnect & how?
Barbara Hettwer
Hi Barbara
Regards
Matt
