not able to connect pdu model AP8959
  • not able to connect pdu model AP8959
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-07-09 04:26 AM . Last Modified: ‎2024-02-14 10:21 PM
5266
I connect APC PDU serial port with console cable with the following configuration,
RJ-12          DB-9
2----------------5
3----------------2
4----------------3
I use HyperTerminal software for serial connection, with following settings,
57600 baud rate, 8 data bit, no parity, 1 stop bit, no flow control
but I am unable to communicate with PDU. I use the following procedure,
1- press reset button for 2 seconds and instantly press enter 5 to 10 times in hyper terminal software,
 but no display on hyper terminal.
2- press enter 5 to 10 times and then press the reset button, but the same result.
I checked following,
i- the computer is directly connected to serial port of PDU,
ii- computer's com port is enabled,
iii- no services using com port,
iv- scroll lock button is not pressed.
What should I do for communication with PDU?
because my PDU is not responsive currently, as no display is on PDU.
red coloured led is on status.
hello , you need to use an original APC cable , the part number is 940-0144 , then you can  Run a terminal program (such as HyperTerminal®) and configure the selected port for 9600 bps, 8 data bits, no parity, 1 stop bit, no flow control.
you cant do it with another communication  cable.
owendelong
owendelong
Cadet
Posted: ‎2024-02-06 12:59 AM
I am using the correct cables (with a USB adapter) on a pair of AP8959 units. I can connect to both units, but all I get is weird symbols at random intervals. It's basically as if the baud rate or serial parameters are wrong, but I am definitely using 57600,cs8,-parenb,-ixon,-ixany,-crtscts and the system definitely defaults to 1 stop bit (screen on a Linux system).
I've tried other baud rates as well with no luck. (2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400).
Any other suggestions?
dpierce4776
Lt. Commander dpierce4776
Lt. Commander
Posted: ‎2024-02-06 08:45 PM
The correct hyperterminal settings are 9600 8 1 none none.
If that doesn't work then you most likely have a bad cable.
