84422members
353606posts
ap7723 snmp Monitoring current load
dalbjerg_apc
338
This was originally posted on APC forums on 4/21/2017
Hi
I have googled, to try find out what OID, i should use, to monitoring a AP7723 Current load.-
In the web interface i can see the load is now 5AMP, but witch OID in SNMP should i used to see this number to SNMP?
Hope someone can help me.
Thx.
Regards Kenneth Dalbjerg
Tags (4)
Re: ap7723 snmp Monitoring current load
This reply was originally posted by Angela on APC forums on 4/24/2017
Hi Kenneth,
Please look at the following OID in the APC PowerNet MIB: .1.3.6.1.4.1.318.1.1.8.5.4.3.1.4 (.iso.org.dod.internet.private.enterprises.apc.products.hardware.automaticTransferSwitch.atsStatus.atsStatusOutput.atsOutputPhaseTable.atsOutputPhaseEntry.atsOutputCurrent)
I used a MIB browser which is helpful to see all of the OIDs available, especially if you may be interested in other OIDs like the output VA.
2 Replies 2
Hi Kenneth,
dalbjerg_apc
This was originally posted on APC forums on 4/24/2017
Thank you. I also think it was this one, but it response, was ten time high, than it should be.
Just google it, and it says it gives the status in milli amps 🙂
Again thanks for you help
