UPS: The output has a short-circuit
  • UPS: The output has a short-circuit
Posted: ‎2021-06-25 11:09 PM . Last Modified: ‎2024-03-19 03:19 AM
4645
Anyone experience UPS: The output has a short-circuit that commanded outlet groups to turn off when accidentally tripped the input cable?
Should the ups would battery mode and not to turn off the outlet group?
Device: SRT 5000
Logs:
04/02/2019 08:45:13 Device UPS: The power for switched outlet group 2, Outlet Group 2, is now turned off. 0x0135
04/02/2019 08:45:13 Device UPS: The power for switched outlet group 1, Outlet Group 1, is now turned off. 0x0135
04/02/2019 08:45:12 Device UPS: The output no longer has a short-circuit. 0x015E
04/02/2019 08:45:04 System Email: Could not resolve 'smtp.office365.com'. 0x001A
04/02/2019 08:44:34 System Email: Could not resolve 'smtp.office365.com'. 0x001A
04/02/2019 08:44:06 Device UPS: Switched outlet group 2, Outlet Group 2, has been commanded to turn off, sequenced. 0x0174
04/02/2019 08:44:06 Device UPS: Switched outlet group 1, Outlet Group 1, has been commanded to turn off, sequenced. 0x0174
04/02/2019 08:44:05 Device UPS: The output power is turned off. 0x0114
04/02/2019 08:44:05 Device UPS: The graceful shutdown period has ended. 0x014F
04/02/2019 08:44:05 Device UPS: The output has a short-circuit. 0x015D
03/31/2019 13:15:08 Device UPS: Self-Test passed. 0x01D2
03/31/2019 13:14:47 Device UPS: Self-Test started by management device. 0x0137
  • Getting Started
Had the same thing happened a day ago although i don't know the reason.
Currently I've just replaced it with a spare but i really need to find out why this happened?
Below are the logs.
05-Jun-19 13:36:37 Device UPS: The output power is turned off. 0x0114
05-Jun-19 13:36:37 Device UPS: The output power is now turned on. 0x0113
05-Jun-19 13:36:37 Device UPS: The graceful shutdown period has ended. 0x014F
05-Jun-19 13:36:36 Device UPS: The power for switched outlet group 3, Outlet Group 3, is off. 0x0186
05-Jun-19 13:36:36 Device UPS: The power for switched outlet group 2, Outlet Group 2, is off. 0x0186
05-Jun-19 13:36:36 Device UPS: The power for switched outlet group 1, Outlet Group 1, is off. 0x0186
05-Jun-19 13:36:36 Device UPS: The output has a short-circuit. 0x015D
05-Jun-19 13:36:34 Device UPS: Restored the local network management interface-to-UPS communication. 0x0101
05-Jun-19 13:36:23 System Network service started. IPv6 address FE80::2C0:B7FF:FE9B:BA71 assigned by link-local autoconfiguration. 0x0007
05-Jun-19 13:36:20 System Network service started. System IP is 10.147.162.199 from manually configured settings. 0x0007
05-Jun-19 13:36:13 System Network Interface coldstarted. 0x0001
05-Jun-19 13:19:04 System Network service started. IPv6 address FE80::2C0:B7FF:FE9B:BA71 assigned by link-local autoconfiguration. 0x0007
05-Jun-19 13:19:02 System Network service started. System IP is 10.147.162.199 from manually configured settings. 0x0007
05-Jun-19 13:18:54 System Network Interface coldstarted. 0x0001
05-Jun-19 13:18:33 Device UPS: Self-Test started by automatic timer. 0x0137
30-May-19 12:49:28 System Web user 'apc' logged out from 10.147.16.118. 0x001F
Any help or explanations as to why this happened would be much appreciated.
  • shortcircuit
  • smx1500rmi2unc
Below are the logs.
  • shortcircuit
  • smx1500rmi2unc
