Posted: 2023-04-21 06:50 AM
as many other subjects I've the same problem. The solutions with power cycle and so on didn't solve my problem. As I saw in the eventlog the problem appeared just after I changed paramaters in the SNMP area. I turned back the original items b ut the problem is still the same. What may be the correction?
Eventlog:
04/21/2023 13:14:20 Device UPS: The local network management interface-to-UPS communication not established. 0x0102
04/21/2023 13:13:44 System Network service started. System IP is 192.168.248.xxx from DHCP server 192.168.248.xxx with 863992 second lease. 0x0007
04/21/2023 13:13:31 System Network service started. IPv6 address FE80::2C0:B7FF:FEB7:34D8 assigned by link-local autoconfiguration. 0x0007
04/21/2023 13:13:24 System Network Interface restarted. 0x0002
04/21/2023 13:13:16 System Network Interface restarting. 0x0009
04/21/2023 13:13:16 System Web user 'apc' logged out from 192.168.248.xxx. 0x001F
04/21/2023 13:10:16 apc Configuration change. SNMP access control 1 access enable. 0x0033
04/21/2023 13:09:48 apc Configuration change. SNMP user profile 1 privacy protocol. 0x0033
04/21/2023 13:09:48 apc Configuration change. SNMP user profile 1 authentication protocol. 0x0033
04/21/2023 13:09:48 apc Configuration change. SNMP user profile 1 access type. 0x0033
04/21/2023 13:09:47 apc Configuration change. SNMP user profile 1 privacy passphrase. 0x0033
04/21/2023 13:09:45 apc Configuration change. SNMP user profile 1 authentication passphrase. 0x0033
04/21/2023 13:09:43 apc Configuration change. SNMP user profile 1 user name. 0x0033
04/21/2023 13:08:21 apc Configuration change. SNMPv3 Access 0x0033
04/21/2023 13:08:09 apc Configuration change. SNMPv3 Access 0x0033
04/21/2023 13:07:45 apc Web user 'apc' logged in from 192.168.248.xxx. 0x0015
Posted: 2023-04-22 03:32 AM
As decribed I tried to uddate the NMC2 firmware. During the uüdate I got an error an aborted the task. Surprise! The UPS was visible again.
Here the log:
Device UPS: Restored the local network management interface-to-UPS communication.
System Network service started. IPv6 address FE80::2C0:B7FF:FEB7:xxxx assigned by link-local autoconfiguration.
Even we didn't find the reason for the primary problem we can close my ticket.
Here the log:
