Share Your Feedback โ€“ Help Us Improve Search on Community!
The APC UPS 3000 showing a P.17 fault code indicates a bypass relay weld error
Showing results forย
Did you mean:ย
  • The APC UPS 3000 showing a P.17 fault code indicates a bypass relay weld error
chargr
chargr
Cadet
Posted: โ€Ž2025-06-20 06:58 AM
1039
We're getting a p.17 error code and alerts from the unit.  We tried to clear the code using the following procedures listed below. We suspect a power surge may have caused the problem. Since its happening again we're assuming the unit could be damaged. PLease advise
Model
Smart-UPS 3000
Location
Unknown
 2 Critical Alarms Present
  • Green relay error.
  • The output power is turned off.
 2 Warning Alarms Present
  • The power for the main outlet group, Unswitched Group, is now turned off.
  • The power for switched outlet group 1, Outlet Group 1, is now turned off.
06/19/2025โ€‚โ€‚12:38:21โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: The power for switched outlet group 1, Outlet Group 1, is now turned off.โ€‚โ€‚โ€‚โ€‚โ€‚โ€‚0x0135
06/19/2025โ€‚โ€‚12:38:21โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: The power for the main outlet group, Unswitched Group, is now turned off.โ€‚โ€‚โ€‚โ€‚โ€‚โ€‚0x0135
06/19/2025โ€‚โ€‚12:38:21โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: Green relay error.โ€‚0x01BD
06/19/2025โ€‚โ€‚12:38:20โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: The output power is turned off.โ€‚โ€‚โ€‚โ€‚โ€‚โ€‚0x0114
06/19/2025โ€‚โ€‚12:38:20โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: The graceful shutdown period has ended.โ€‚โ€‚โ€‚โ€‚0x014F
06/19/2025โ€‚โ€‚12:38:20โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: Switched outlet group 1, Outlet Group 1, has been commanded to turn off, sequenced.โ€‚โ€‚0x0174
06/19/2025โ€‚โ€‚12:38:20โ€‚โ€‚โ€‚โ€‚Deviceโ€‚โ€‚โ€‚โ€‚โ€‚โ€‚UPS: Main outlet group, Unswitched Group, has been commanded to turn off, sequenced.โ€‚โ€‚โ€‚โ€‚โ€‚โ€‚0x0174
We tried this already on 6/13/25 and 6/20/25 when the error came back that morning.
  1. Clear the Fault Code
    • From the LCD menu, navigate to Diagnostics or Event Log and use the โ€œClearโ€ or โ€œResetโ€ option.
    • If unsuccessful, power-cycle the UPS: fully shut down, wait 30 seconds, reconnect, and power up.
  2. Run a โ€œBrain Deadโ€ Reset
    • Also known as a hard reset or cold start, this clears any residual internal faults. On many models:
      • Disconnect both input & output power.
      • Remove the battery.
      • Wait ~1โ€“2 minutes.
      • Reinstall battery, reconnect power, and restart UPS.community.se.com+1apc.com+1
  3. Inspect or Replace Bypass Relay Assembly
    • If the fault persists or recurs soon after reset, the bypass relay hardware may be physically welded.
    • Contact APC/Schneider or a certified service center for relay inspection or replacement.
  4. Test Thoroughly Post-Repair
    • After clearing the fault, perform a Full Self-Test via the LCD: confirm the unit switches cleanly and no new errors appear.
Kirk
Posted: โ€Ž2025-06-20 12:52 PM
If the equipment is still under warranty contact APC Technical Support to initiate a RMA. If the unit is not under warranty than it really depends upon what standards your company operates under. If your company follows the most stringent ISO standards than the hardware will need to be replaced.
If its less stringent that you may consider shipping the hardware out to an APC Authorized Repair Facility such as https://coasttec.com/service/repair-and-return/
If you don't follow any ISO standards than you may consider sending the unit out to any electronics facility to have them replace all of the relays in the unit. Don't simply replace the failed welded relay because you're simply living on borrowed time!
Replace all of the relays and obviously have them inspect and test all of the MOV, GDT, Fuse, in the SPD circuit.
Questions Ask . . . ๐Ÿ‘
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
