Smart-UPS RT 3000 XL - UPS Output Power Keeps Turning Off
  • Smart-UPS RT 3000 XL - UPS Output Power Keeps Turning Off
Posted: ‎2021-06-29 01:12 AM . Last Modified: ‎2024-03-13 11:24 PM
1210
We have a Smart-UPS RT 3000 XL which seems to turn off the output power every time it performs a self-test. The UPS has a 9630 network management card installed.
The logs seem to indicate problem occurs during self-tests - or that the self tests are run after/during the problem - We're not sure.
The UPS is currently online with no alarms present. Battery capacity is at 100% Load at 20%. Can anyone assist? Is this a bug? Hardware problem?
Here are the logs:
 Date Time Event
 10/27/2010 4:06:36 UPS: The output power is turned off.
 10/27/2010 4:15:01 UPS: Started a self-test.
 10/27/2010 4:15:01 UPS: The output power is now turned on.
 10/27/2010 4:15:16 UPS: Passed a self-test.
 11/03/2010 3:30:17 UPS: The output power is turned off.
 11/03/2010 3:34:49 UPS: Started a self-test.
 11/03/2010 3:34:49 UPS: The output power is now turned on.
 11/03/2010 3:35:05 UPS: Passed a self-test.
 11/09/2010 1:24:57 UPS: The output power is turned off.
 11/09/2010 1:31:28 UPS: Started a self-test.
 11/09/2010 1:31:28 UPS: The output power is now turned on.
 11/09/2010 1:31:43 UPS: Passed a self-test.
 11/10/2010 1:21:09 UPS: The output power is turned off.
 11/10/2010 1:25:01 UPS: Started a self-test.
 11/10/2010 1:25:01 UPS: The output power is now turned on.
 11/10/2010 1:25:17 UPS: Passed a self-test.
11/11/2010 2:09:07 UPS: The output power is turned off.
11/11/2010 2:14:06 UPS: Started a self-test.
11/11/2010 2:14:06 UPS: The output power is now turned on.
11/11/2010 2:14:22 UPS: Passed a self-test.
Posted: ‎2021-06-29 01:13 AM . Last Modified: ‎2024-03-13 11:23 PM
ok. can you provide the firmware versions of both the UPS and the NMC?
it does sound like a UPS issue here but lets just check.
if you log into the NMC, check the UPS tab->About for the UPS firmware and then the NMC firmware is under the Administration tab->General->About.
thanks!
Replies 4
Thanks for the assistance... here is the information.
Model: Smart-UPS RT 3000 XL
Position: TOWER
Firmware Revision: 450.14.W
Manufacture Date: 02/19/06
Model Number: AP9630
Hardware Revision: 05
Manufacture Date: 08/17/2009
MAC Address: 00 C0 B7 4D 9F AD
Management Uptime: 33 Days 9 Hours 6 Minutes
Application Module
Version: v5.0.3
Date: Aug 6 2009
Time: 21:53:59
APC OS (AOS)
Version: v5.0.3
Date: Aug 4 2009
Time: 13:12:44
APC Boot Monitor
Version: v1.0.0
Date: Oct 8 2008
Time: 16:03:02
you are seeing the messages in the log but is the actual power turning off which is causing your load to turn off?
Yes, the output power is being shut off, causing our network equipment to power down/reload.
thanks!
