Posted: 2025-08-24 10:37 PM
Hi
I can't get 2 NMS hosts for SNMPv3 using the same username working. Only the first one in the list works. Is it possible to have more than 1 NMS host using a particular SNMPv3 username? If I use 0.0.0.0 or 10.255.255.255 both hosts will work but I'd like to restrict it to the server's IP address. They are in different /16 ranges.
Posted: 2025-08-26 05:29 AM
You can use the same User Profile on all NMS. You can only have (4) defined inbound IP Addresses within the NMC to allow the SNMP connection.
All target devices must be on the same subnet / range unless you have defined this within your firewall to allow the traffic through.
Questions Ask . . . 👍
Posted: 2025-08-26 09:18 PM
I can't get it working. If I use the same username against 2 IP addresses, only the first one listed will work. The second one does not work. So I've tested the 2 IP addresses individually and they can connect but when they are listed as the second profile, they don't work. Is there a trick to get the second one working?
Posted: 2025-08-27 01:46 AM
Show me an image capture of all the SNMP settings.
There’s no trick to what I stated it just works on millions of units in my fleet.
