SNMP OID result not consistent with what's shown in the Web Interface
Send InviteCancel
Posted: 2024-02-1909:36 PM
I just experienced same behavior. My monitoring SW queries 1.3.6.1.4.1.318.1.1.1.2.2.4.0 which reports 1 (Battery doesn't need to be replaced),. At the same time 1.3.6.1.4.1.318.1.1.1.2.2.21.0 reports a date in the past (battery meant to be replaced on that day). I would expect that if 1.3.6.1.4.1.318.1.1.1.2.2.21.0 is in the past, that 1.3.6.1.4.1.318.1.1.1.2.2.4.0 would be equal to 2 (battery needs replacement) When I login to Web of the UPS, I'm getting alert that battery does needs to be replaced.
Can somebody please explain meaning of these OIDs and if they are/meant to be linked?
Thank you Tomas 1.3.6.1.4.1.318.1.1.1.2.2.4.0 1.3.6.1.4.1.318.1.1.1.2.2.21.0
