Posted: 2022-11-14 01:38 AM
we're using PowerChute Network Shutdown for Nutanix AHV. I'm able to connect via SSH with username and password. But I can't connect to the cluster with SSH public/private key authorization:
The public key is on the Nutanix nodes and I'm able to connect via Windows Terminal under Windows 10. I've added the path to the SSH key: C:\Program Files\APC\PowerChute\user_files\id_rsa But the following error always appears: "Nutanix AHV Hosts are inaccessible. Please verify that the Nutanix AHV Host credentials are correct and that all Host IPs are accessible over the network."
Any ideas?
Best regards,
Martin
Posted: 2022-11-15 01:48 AM
Update: the "sshservice" file shows the following error while using key authorization:
2022-11-15T10:26:04,986 DEBUG qtp1529921410-232 com.apcc.pcns.sshservice.SshSessionImpl - Connecting to host 10.110.4.11 now
2022-11-15T10:26:05,107 DEBUG qtp1529921410-232 com.apcc.pcns.sshservice.SshSessionImpl - Authenticating with host 10.110.4.11 now, using key.
2022-11-15T10:26:05,147 ERROR qtp1529921410-232 com.apcc.pcns.sshservice.SshSessionImpl - SSH authentication failed with error Exhausted available authentication methods
2022-11-15T10:26:05,147 DEBUG qtp1529921410-232 com.apcc.pcns.sshservice.GenericSSHConnection - connect() - starting SSH connection failed with error {}
javax.naming.AuthenticationException: Failed to connect session due authentication failure
at com.apcc.pcns.sshservice.SshSessionImpl.startConnection(Unknown Source) ~[pcns.jar:?]
at com.apcc.pcns.sshservice.GenericSSHConnection.connect(Unknown Source) ~[pcns.jar:?]
at com.apcc.m11.components.webserver.servlets.AJAXCheckHostConnection.checkNutanixClusterConnection(Unknown Source) ~[pcns.jar:?]
at com.apcc.m11.components.webserver.servlets.AJAXCheckHostConnection.checkNutanixAHVConnection(Unknown Source) ~[pcns.jar:?]
at com.apcc.m11.components.webserver.servlets.AJAXCheckHostConnection.doPost(Unknown Source) ~[pcns.jar:?]
at com.apcc.m11.components.webserver.servlets.AJAXServlet.doPost(Unknown Source) ~[pcns.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[servlet-api-3.1.jar:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[servlet-api-3.1.jar:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:791) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1626) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at com.apcc.m11.components.webserver.filters.HeaderFilter.doFilter(Unknown Source) ~[pcns.jar:?]
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[jetty-security-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1435) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[jetty-servlet-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1350) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:273) [jetty-server-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [jetty-io-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:375) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:773) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:905) [jetty-util-9.4.35.v20201120.jar:9.4.35.v20201120]
at java.lang.Thread.run(Thread.java:832) [?:?]
Posted: 2022-11-17 07:22 PM
I recommend getting in contact with our Technical Support Team for your country and providing them with the files needed to investigate further on this issue along with screenshots of the error that you are getting.
You may use the FAQ article and Support Site below for your guide.
Posted: 2023-01-19 04:59 AM
Hi, this issue still exists. I opened a support request (ID 96570909, esupport.emeade@schneider-electric.com) in November and explained the issue in several mails. But since December I have not received any more response on the status. I asked several times - no answer. What can I do?
Posted: 2023-01-19 11:26 AM
We apologize for the delayed follow-up on your case.
Our engineers have been reviewing this issue. They have not been able to determine the exact cause of the connection failure. As soon as we have more information, your support case will be updated, and you will be e-mailed.
Again, we apologize for the delayed follow-up.
Posted: 2023-01-20 04:45 AM
Thank you very much!
