Power management multiple Apple computers with Pro 1300 / 1500
  • Power management multiple Apple computers with Pro 1300 / 1500
Posted: ‎2021-07-01 01:37 AM . Last Modified: ‎2024-03-06 01:31 AM
2259
Its very easy to manage the preferences off just one Mac with the USB cable connected to the APC.
How about a 2nd Apple computer and a Synology DS1510+ ?
Can I connect all off them via a USB splitter?
Is there a network option?
The connection on the APC looks like a Ethernet Jack. Can I connect it to my home network?
Thanks!
Rogier
  • hub
  • mac
  • manage
  • multiple
  • nas
  • network.
  • pc
  • power
  • synology
I had the same problem. One UPS, 4 PC (NAS) and an iMac to control.
My solution works and has been robustly tested to shutdown MAC and PC - with a cancel option for PC (can't do it on mac once shutdown -h has been invoked)
HOW TO REMOTE SHUTDOWN ALL MACHINES (PC and MAC) ATTACHED TO AN APC UPS
To remotely shutdown any PC on the same network:
CHANGE THE FOLLOWING SETTINGS ON EACH REMOTE COMPUTER:
In CONTROL PANEL
Network and Sharing Center, Change Advanced Sharing settings
"Private" enable "Turn on File and Printer sharing"
In REGEDIT
RUN regedit.exe
Add a new DWORD
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
LocalAccountTokenFilterPolicy  DWORD:00000001
In SECPOL (Windows Pro and Enterprise ONLY)
RUN secpol.msc
Local Security Policy, Security Settings, Local Policies, User Rights Assignment
Add "Everyone" to "Force shutdown from a remote system"
Then set up the event task in TASK SCHEDULER from the PC with the UPS attached to it.
RUN taskschd.msc
TO SHUTDOWN ALL NOMINATED MACHINES
CREATE BASIC TASK
Give the TASK a NAME and a DESCRIPTION [next]
Trigger: “When a specific event is logged” [next]
When an event is logged:
LOG: Application
SOURCE: APC UPS SERVICE
EVENT ID: 174
[next]
ACTION: “Start a program” [next]
START A PROGRAM
c:\scripts\upsshutdown.bat [next]
[finish]
TO CANCEL SHUTDOWN OF ALL NOMINATED MACHINES
CREATE BASIC TASK
LOG: Application
EVENT ID: 61455
[next]
START A PROGRAM
c:\scripts\upscancelshutdown.bat [next]
[finish]
BATCH FILES (to be added to c:\scripts\)
upsshutdown.bat
shutdown /s /m \\computer_name /t 120 /c “AC BLACKOUT - ORDERED SHUTDOWN IN PROGRESS”
add one line per PC you want to shutdown.
shutdown /a /m \\computer_name
add one line per PC you want to cancel the shutdown process
END OF PC METHOD
To remotely shutdown any MAC on the same network
Make sure the mac is visible on the PC with the UPS attached to it and the MAC user area is shared.
edit the ups shutdown.bat file and add the following lines for each MAC you want to shut down.
net use x: \\MAC-NAME\username
del x:\shutdown.txt
echo shutdown > x:\shutdown.txt
net use x: /delete
On each MAC
Open Automator (applications -> automator)
Choose “Folder Action” and click  “choose”
Click the “Choose folder” dialog box, select “other” and select the default user folder that corresponds to \\MAC-NAME\username and click “choose”
In “Library -> utilities” select “Run AppleScript” and drag the action into the right hand panel
replace the default AppleScript with the following:
on run {input, parameters}
 tell application "Finder"
   if exists POSIX file "/users/timstevenson/shutdown.txt" then
     say "There has been a power cut. I'm going to shutdown in one minute."
     delay 60
     tell application "System Events"
       set ProcNm_ to name of every application process whose visible is true
       repeat with i_ from 1 to count items of ProcNm_
         set TarProc_ to item i_ of ProcNm_
         try
           tell application TarProc_ to quit
         end try
       end repeat
         try
           if TarProc_ does not equal "Finder" then set app_name to TarProc_
           set the_pid to (do shell script "ps ax | grep " & (quoted form of app_name) & " | grep -v grep | awk '{print $1}'")
           if the_pid is not "" then do shell script ("kill -9 " & the_pid)
         end try
       end repeat
       tell application "finder" to shut down
     end tell
   end if
 end tell
return input
end run
SAVE the Automator file as UPSShutdown
END OF MAC METHOD
  • network
  • ups
unfortunately, this cannot be done with a Back UPS product. the data connection you see is RJ-45 but it is only a similar connection type, not a network connection.
each Back UPS can only support a single USB connection to a computer. you cannot use a USB hub or similar to attach multiple devices because you can only run one instance of software - whether you use ours or apple's native support.
to shutdown or monitor multiple devices with a single UPS, you'd need a Smart UPS product with a network management card.
Thanks for the reply, I also figured it out by experimentation.
However when I connected it to a Synology DS1512+ I did see a option in their software to set an IP address...
Something new to learn....
In CONTROL PANEL
In REGEDIT
RUN regedit.exe
Add a new DWORD
RUN secpol.msc
RUN taskschd.msc
CREATE BASIC TASK
LOG: Application
EVENT ID: 174
[next]
START A PROGRAM
[finish]
CREATE BASIC TASK
LOG: Application
EVENT ID: 61455
[next]
START A PROGRAM
[finish]
upsshutdown.bat
END OF PC METHOD
del x:\shutdown.txt
net use x: /delete
On each MAC
     delay 60
         try
         end try
       end repeat
         try
         end try
       end repeat
     end tell
   end if
 end tell
return input
end run
END OF MAC METHOD
  • network
  • ups
