Share Your Feedback โ€“ Help Us Improve Search on Community!
Measuring individual outlet loads on AP7922
Showing results forย
Did you mean:ย
  • Measuring individual outlet loads on AP7922
5060
143
Posted: โ€Ž2021-06-28 03:19 AM . Last Modified: โ€Ž2024-03-18 04:44 AM
2024
Is it possible to get the individual outlet loads on AP7922 models? Getting the bank load is pretty simple via either the Web UI or SNMP:
bq. PowerNet-MIB::rPDULoadStatusLoad.1 = Gauge32: 48 \\ PowerNet-MIB::rPDULoadStatusLoad.2 = Gauge32: 29 \\ PowerNet-MIB::rPDULoadStatusLoad.3 = Gauge32: 23
However, the PowerNet-MIB::rPDUOutletStatusLoad.* OIDs on SNMP all return zero, regardless of what load is pulled on each outlet:
bq. PowerNet-MIB::rPDUOutletStatusLoad.1 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.2 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.3 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.4 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.5 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.6 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.7 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.8 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.9 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.10 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.11 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.12 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.13 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.14 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.15 = Gauge32: 0 \\ PowerNet-MIB::rPDUOutletStatusLoad.16 = Gauge32: 0
-z
  • management
  • pdu
  • snmp
Cap1_apc
Lt. Commander Cap1_apc
Lt. Commander
Posted: โ€Ž2021-06-28 03:20 AM . Last Modified: โ€Ž2024-03-18 04:44 AM
Individual outlet monitoring is not possible on APC's current switched rack pdu's (AP79xx). To get this functionality it would be necessary to put a clamp meter on every outlet. Currently we clamp the bank (or phase) depending on model. So it is a physical impossibility, not a MIB or firmware issue. The MIB has these OID's for future hardware development opportunities.
Replies 8
i hear you on the PDU thing - I am not sure. it may have been carried over from another older device that supported it, i am not sure.
[check this out|http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=9431]
i believe it will answer your question. let me know if you need anything else ๐Ÿ˜‰
Doesn't really answer the question. I know what rPDULoadStatusLoad is and what it means. What I'm trying to do is measure the load on each individual outlet, not the per-bank load. Can this even be done on an AP7922. If not, what PDU models support this?
-z
oh, sorry. basically that shows you the information you will get. i dont believe its possible to measure the load on each particular outlet, only by bank. if you were able to, i believe it'd be an option in the web/telnet interfaces as well and it is not. i dont believe we make any single phase PDUs that do that unfortunately :-(. don't think there are any three phase ones either but i am not too familar with them.
thanks for your help anyway.
-z
Unfortunately, APC does not make a rack PDU that measures the load for each individual outlet. Only per power strip.
Message was edited by: i picKed a winna - there was a violation of APC Forum Rules of Online Behavior - "Contains business solicitation of any type, including advertising a product or service, offering a product or service for sale, or directing readers to a location for more information about a product or service"
Well, that sucks, no doubt about it. Why bother having a MIB entry for individual PDU outlet loads if none of your products actually support it?
-z
Cap1_apc
Lt. Commander
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
