M172 programmatically read/write Modbus TCP via Ethernet Port
  • M172 programmatically read/write Modbus TCP via Ethernet Port
Eddie.Li
Eddie.Li
Cadet
Posted: ‎2025-04-04 01:05 PM
I'm very new to the M172 and EcoStruxure Machine Expert HVAC, and I'm primarily using Structured Text to program the M172 PLC.
I’ve configured the M172 as a Modbus TCP Master and added slave devices under the Ethernet Configuration. I understand that I can assign Modbus functions and status variables directly through the configuration, but I’m exploring whether I can handle Modbus communications programmatically instead—so I can catch and process return values from each read/write operation.
I used the sysMbS_AcceptClient function to accept connections from Modbus clients based on their IP addresses. It returned 0, which suggests the parameters were loaded correctly. However, when I use sysMbMTCP_FC03 and sysMbMTCP_FC06 in a background task to read/write to the same Modbus client, I consistently receive error code 14 (Invalid response message).
Interestingly, when I configure and access the same client manually via the Ethernet Configuration tab, read/write operations work as expected.
Unfortunately, I haven’t been able to find clear documentation or Structured Text examples for using sysMbS_AcceptClient, sysMbMTCP_FC03, and similar target functions to help with further debugging.
Any guidance or examples on the correct usage of these functions for programmatic Modbus communication with the M172 would be greatly appreciated.
Thank you!
Replies 0
