Flat battery alert
Send InviteCancel
Posted: 2022-04-2303:21 PM
Flat battery alert
I have a Smart 1500VA UPS that I bought in 2015. The alert is saying "Warning battery / Connect battery". The battery level appears to be zero. Assuming that is correct, power is still passing through, which is a relief. I can't order a replacement until Tuesday (because of Easter). I'm wondering if there's any risk of the power not passing through until a replacement arrives.
Also, is it possible to disable the clicking sound that it emits every few seconds?
