Feature Request, Site Wiring Fault
Send InviteCancel
Posted: 2021-06-2910:52 PM. Last Modified: 2024-03-1201:05 AM
I have another AP9631 with a site wiring fault, this one is at a job shack/construction trailer, so the wiring is sketchy, and construction workers are prone to plugging in tools anywhere there is an outlet (like a UPS). I know there are three possible causes of a site wiring fault. If the AP9631 recognizes there is a problem, couldn't it also tell me what the problem is? Or log the data that would point me towards the error? Tell me what the volts on neutral is, or it can't measure volts to ground, or whatever it thinks the problem is. Instead of telling the electrician what the possible problems are, with the data I could tell the electrician details!
If the data (volts on neutral for example) would clog up the logs, perhaps make it optional to log the data.
