Change Output voltage Smart-UPS
Send InviteCancel
Posted: 2021-06-2808:14 AM. Last Modified: 2024-03-1812:01 AM
When i first got my SMC1000I i was stumped as to why my menu screen was missing the Output voltage setting. After some playing around i found it could only be accessed when the power button was turned off (output power off)
For some reason APC forgot to mention this in their manual, even tech support wasn't about to communicate this! Hope they note this in the next manual revision.
So in order to change the output voltage you have to turn off the output power (press the power button for 2 seconds) The screen will go off, but then press the speaker and menu button for 2 seconds and now the output voltage screen will be available in the menu options.
Also i thought pressing the power button turns off the unit, but it just cuts the output power.
