Ceiling Ideas
Send InviteCancel
Posted: 2021-06-2510:42 PM. Last Modified: 2024-03-1903:34 AM
Ceiling Ideas
I am currently building about a 6k sq ft datacenter. The building is a single floor building, so my ceiling is currently the roof deck. I will be using the "slab" configutration with no raised floor. All cooling will be from InROW RPs. I am not sure what the best thing to do in regards to the ceiling. Should i leave it alone or install drop ceiling (good vinal kind). From what i understand having a high ceiling height is a positive, but i am worried about heat being induced into the room when the roof heats up in the summer.
