AppleScript solutions for APC interface
  • AppleScript solutions for APC interface
Posted: ‎2021-06-28 02:47 AM . Last Modified: ‎2024-02-14 10:46 PM
781
Where can I find applescript examples or solutions for remote login and manipulation of an APC 7900 or similar? The supported resources for Macintosh users are slim. Thanks.
  • apc_7900
  • network_management_card
  • NMC
  • pdu
  • snmp
Janeway
I'm not familiar with the capabilities of the APC 7900. I will try to address the more general question of how to manipulate APC devices using AppleScript.
The best approach I know of for programmatically manipulating APC devices is through SNMP. MacOS X ships with SNMP software built-in. This blog article seems to have a thorough description of the technology: [A Primer to SNMP on Mac OS X 1.5|http://www.bynkii.com/archives/2007/12/a_primer_to_snmp_on_mac_os_x_1.html]
You can use the command line SNMP programs with the various programming tools shipped with MacOS X, such as Python, Perl, Ruby, and AppleScript. This technote seems to describe how to use command line programs such as the SNMP suite with AppleScript: [TN2065: Do Shell Script in AppleScript|http://developer.apple.com/technotes/tn2002/tn2065.html]
So lets say I want to command a switched PDU to turn off all outlets. If it supports the sPDUMasterControlSwitch OID (1.3.6.1.4.1.318.1.1.4.2.1) then I should be able to do something like this (with ip_goes_here replaced with appropriate IP):
do shell script "/usr/bin/snmpset -c private -v 1 ip_goes_here 1.3.6.1.4.1.318.1.1.4.2.1.0 i 7"
then to turn them back on:
do shell script "/usr/bin/snmpset -c private -v 1 ip_goes_here 1.3.6.1.4.1.318.1.1.4.2.1.0 i 1"
You may need to change the snmp version (-v), the community string (-c), or other options for your setup. If you're using SNMPv1, I'd suggest you get it working with that and then move to SNMPv3 for security.
If you have any further questions, let us know.
Janeway
