APC rack pdu model AP7921 issues with network management after power off
  • APC rack pdu model AP7921 issues with network management after power off
massimo2017_apc
Ensign massimo2017_apc
Ensign
Posted: ‎2021-07-11 10:29 PM . Last Modified: ‎2024-02-14 03:19 AM
1219
Hi all,
APC rack pdu model AP7921 after black out or simple power off when it turns on the network management card lost completely IP communication.
Even ping do not work anymore, so that i've to turn off again and again a number of times since the network management card becomes accessible in the LAN again.
Application Module
Version: v3.7.4
Date: 03/13/2012
Time: 16:16:54
APC OS (AOS)
Version: v3.7.4
Date: 11/09/2011
Time: 11:45:09
Any help?
I've the issue since i bought the rack PDU (years ago).
thanks
regards
massimo s.
massimo2017_apc
Ensign
I upgraded AOS and firmware to version 3.9.2 (2016).
Thanks for the suggestion.
Let's see how it works in the future, since it loose the LAN connectivity after a blackout.
Regards.
Massimo
Posted: ‎2021-07-11 10:29 PM . Last Modified: ‎2024-01-31 03:01 AM
Hi Massimo,
If the unit was new and in warranty I'd advise that you contact support to replace, for now you could try to update to firmware but I'm unsure it will help.
https://www.apc.com/shop/gm/en/products/Switched-Metered-Rack-Power-Distribution-Unit-Firmware-Revis...
- Gavan
massimo2017_apc
Ensign
Regards.
Massimo
