Posted: 2021-06-25 11:22 PM . Last Modified: 2024-03-19 03:09 AM
Getting the error F04 when trying to power on. How can i check if this is a battery problem or not.
Model BR1500G-IN
Serial Number : E21530013119
F04 is a clamp short which means there was a surge or multiple surges that the UPS shunted and after the last surge the UPS could not return to normal state.
You can try to resolve by resetting the UPS
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
If that does not resolve the issue the UPS should be replaced. If the unit is under warranty contact local Schneider Electric support for assistance.
Local support contact information will be found at this link.
https://www.apc.com/us/en/support/contact-us/index.jsp
You will need to change the region in the upper left of the contact us web page.
7: Turn UPS on.
