AP9630 configuration ( SMT1500RM2U )
Send InviteCancel
Posted: ‎2024-07-0808:07 PM
I have just set an ip@ on the company's AP9630; via a jack 2.5mm ftdi<->usb cable.
apc>tcpip -i 192.168.1.250 -s 255.255.255.0 -g 192.168.1.1 E002: Success Reboot required for change to take effect.
Naturally I can run an apc>reboot command, that's not an issue, but will this make the entire UPS reboot or just the AP9630 card (meaning that, machines getting power from the UPS will not power-cycle) or should I power down everything attached to this UPS prior to issuing the reboot command?
