AP7921 firmware update failed and unit now not working
  • AP7921 firmware update failed and unit now not working
Posted: ‎2021-07-09 04:13 AM . Last Modified: ‎2024-02-14 11:07 PM
2106
Hi I tried to update the firmware to the current version on the device (details listed below) - but firmware update failed and now I have no web access to the device and no lights on any of the power outlets etc
I can connect via serial cable and via telnet and ftp
If I ftp to the device and ls the only file I see is:
apc_hw02_aos_116.bin
C:\Users\JamesP>ftp 192.168.1.22
Connected to 192.168.1.22.
220 AP7921 Network Management Card AOS v1.1.6 FTP server ready.
500 Syntax error, command unrecognized.
User (192.168.1.22:(none)): apc
331 User name okay, need password.
Password:
230 User logged in, proceed.
ftp> ls
200 PORT Command okay.
150 File status okay; about to open data connection.
226 Closing data connection.
ftp: 25 bytes received in 0.00Seconds 25000.00Kbytes/sec.
ftp>
ftp> bin
200 TYPE Command okay.
ftp> hash
Hash mark printing On ftp: (2048 bytes/hash mark) .
ftp> put C:\Temp\APC\apc_hw02_aos_202.bin
ftp: 1048576 bytes sent in 15.35Seconds 68.31Kbytes/sec.
ftp> ls
Connection closed by remote host.
ftp> open 192.168.1.22
Password:
ftp> ls
ftp>
If I try and ftp another file to it (in binary mode) it appears to go but never arrives at the other end.
I can't delete or rename or copy off the existing *116.bin file
Its as if the ftp has only read rights
I've tried resetting etc via the serial connection but all to no avail.
Help !
About System
Model Number : AP7921
Serial Number : JA0350007617
NMC Serial Number : JA0347003934
Manufacture Date : 12/09/2003
Hardware Revision : B2
MAC Address : 00 C0 B7 6B FD AB
Flash Type : AMD A29DL322DB
Module Information
Description : Network Management Card AOS
Name : aos Type : APC OS
Version : 202 Sector : 39
Date : 12/29/2003 Time : 13:54:07
CRC16 : EDB9
Version : 116 Sector : 63
Date : 02/07/2003 Time : 13:45:39
CRC16 : 9A88
My issue (and version numbers) seem identical to this post - but unfortunately it appears this was resolved over the phone so I'm none the wiser !
http://forums.apc.com/spaces/6/racks-rack-accessories-cooling/forums/general/4028/where-are-the-app-...
And now I have lost connectivity to the unit completely.  Can't access via IP and the serial port has stopped communicating so I suspect the unit is now bricked
Very disappointed that what should be a simple and foolproof upgrade process is so tortuous and the fact that there is no factory reset option for if it goes wrong.
Ok after lots of messing have managed using XModem to copy on:
and then:
apc_hw02_aos_390.bin
and
apc_hw02_rpdu_374.bin
System details now looking as below
If I connect via serial - all seems OK - Amps light reads 0 (with nothing attached), I can switch on and off outlets etc
Status light shows green
However whenever I set an IP (static or DHCP) and restart - I get the amp light showing 88 and the warning light on and I don't appear to be able to connect using telnet or http
I can ping the IP address I have set - so its there - but if I connect via serial I have lost all items under device config.
To get it to work again on serial - I have to select reset to defaults
So I'm now pretty sure that the unit isn't bricked - but something still not quite right with the firmware upgrade with regards to setting IP
Any ideas ?
American Power Conversion Network Management Card AOS v3.9.0
(c) Copyright 2009 All Rights Reserved Rack PDU APP v3.7.4
Name : RackPDU Date : 02/28/2016
Contact : Unknown Time : 12:41:40
Up Time : 0 Days 0 Hours 0 Minutes Stat : P+ N+ A!
About System
Press to continue...
Module Information
Description : Rack PDU APP
Name : rpdu Type : StatApp
Version : 374 Sector : 16
Date : 03/13/2012 Time : 16:16:54
CRC16 : 4D49
Version : 390 Sector : 47
Date : 05/11/2015 Time : 14:45:05
CRC16 : 4138
